So, ive learned to make good bolt holes you need to slow the speed way down, and turn THC off. Well, I modified the candcnc POST for sheetcam, and well...it works. I combined code from a few files to make this. Still messing with it but its made a BIG difference in cut quality of small holes.
Here it is:
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText("johns CNC plasma Settings!!!\n")
ctrl:AppendText("plasma MP1000-THC post processor\n")
ctrl:AppendText("\n")
ctrl:AppendText("Modal G-codes and coordinates\n")
ctrl:AppendText("Comments enclosed with ( and )\n")
ctrl:AppendText("M03/M05 turn the torch on/off\n")
ctrl:AppendText("Incremental IJ - set in mach2\n")
ctrl:AppendText("The torch is referenced at cut start and every 500mm of movement thereafter\n")
ctrl:AppendText("Designed for use with Mach3 and CandCNC MP1000-THC and Floating head Touch-n-Go\n")
ctrl:AppendText("Post variables:\n")
ctrl:AppendText("refdistance - set the distance between each reference\n")
ctrl:AppendText("switchoffset - set your net switch offset amount \n")
end
--post.SetOptions(post.ARC_SEGMENTS)
-- created 1/1/06
-- Based on plasma1.post
function OnInit()
post.SetCommentChars ("()", "[]") --make sure ( and ) characters do not appear in system text
post.Text (" (Filename: ", fileName, ")\n")
post.Text (" (Post processor: ", postName, ")\n")
post.Text (" (Date: ", date, ")\n")
if(scale == metric) then
post.Text (" G21 (Units: Metric)\n") --metric mode
else
post.Text (" G20 (Units: Inches)\n") --inch mode
end
post.Text (" G53 G90 G40\n F1\n")
minArcSize = 0.2 --arcs smaller than this are converted to moves
dist = 9999999
refdistance = 10* scale
--Put your switch offset value here
switchoffset =.3704
lastz = 0
-- set the radius when to go slow and turn off thc
-- radius's above this number will be cut normally
-- Not sure exactly what the slowradius number represents
-- It cant be the radius of the circle in inchs???
-- But i can see if you want it to work on smaller holes RAISE the slowradius
slowradius = 8 * scale
-- Speed you want it to go when it slows down. .3 = 30% normal speed
slowspeed = .3
end
function OnNewLine()
post.Text ("N")
post.Number (lineNumber, "0000")
lineNumber = lineNumber + 10
end
function OnFinish()
endZ = safeZ
OnRapid()
endX = 0
endY = 0
OnRapid()
post.Text (" M05 M30\n")
end
function OnRapid()
dist = dist + math.hypot(endX-currentX , endY-currentY)
post.ModalText (" G00")
post.ModalNumber (" X", endX * scale, "0.0000")
post.ModalNumber (" Y", endY * scale, "0.0000")
post.ModalNumber (" Z", endZ * scale, "0.0000")
post.Eol()
end
function OnMove()
post.ModalText (" G01")
post.ModalNumber (" F", feedRate * scale, "0.0###")
post.Eol()
end
function OnArc()
radius = math.hypot(endX - arcCentreX,endY-arcCentreY) * scale
-- johns mod to slow down feedrate and turn thc off for tight holes
if (radius < slowradius) and (math.abs(arcAngle) > 0.5) then
--feed = (radius / slowradius)
feed = slowspeed
if(feed < slowspeed) then feed = slowspeed end
feed = feed * feedRate
post.ModalText (" m101")
post.Eol()
else
feed = feedRate
post.ModalText (" m102")
post.Eol()
end
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
end
post.NonModalNumber (" X", endX * scale, "0.0000")
post.NonModalNumber (" Y", endY * scale, "0.0000")
post.Text (" I")
post.Number ((arcCentreX - currentX) * scale, "0.0000")
post.Text (" J")
post.Number ((arcCentreY - currentY) * scale, "0.0000")
post.ModalNumber (" F", feed * scale, "0.0###")
post.Eol()
end
function OnPenDown()
if(dist >= (refdistance/scale)) then
dist = 0
-- modaltext (" G00")
-- text(" Z")
-- number (pierceheight * scale, "0.0000")
-- eol()
post.ModalText(" G28.1 Z")
post.Number(3 * scale, "0.00")
post.Eol()
post.ModalText(" G92 Z0.0\n")
post.Text(" Z")
post.Number (switchoffset, "0.0000")
post.Eol()
post.Text(" Z")
post.Number (pierceHeight * scale, "0.0000")
post.Eol()
else
post.Text(" Z")
post.Eol()
end
if (preheat > 0) then
post.Text ("\n G04 P")
post.Number (preheat,"0.###")
post.Eol()
end
post.Text ("\n M03\n")
if (pierceDelay > 0) then
post.Text (" G04 P")
post.Number (pierceDelay,"0.###")
post.Eol()
end
end
function OnPenUp()
post.Text (" M05\n")
if (endDelay > 0) then
post.Number (endDelay,"0.###")
post.Eol()
end
end
function OnNewOperation()
post.Text (" (Process: ", operationName, ")\n")
if (plungeRate <= 0) then
post.Warning("WARNING: Plunge rate is zero")
end
if (feedRate <= 0) then
post.Warning("WARNING: Feed rate is zero")
end
end
function OnToolChange()
post.Text (" M06 T")
post.Number (tool, "0")
post.ModalNumber(" F",feedRate * scale,"0.#")
post.Text (" (", toolName, ")\n")
end
function OnNewPart()
post.Text(" (Part: ",partName,")\n");
end
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
end
