585,715 active members*
3,745 visitors online*
Results 1 to 12 of 12
    Jul 2012
    Distorted Lines and Curves - Vector Cut.
    What would cause distorted lines and curves when operating a GCC Explorer II 60w (vector mode)?
    (Software, issues with X axis, Lenses, Motor?)
    Oct 2007
    385
    I am no expert, but it looks like you may be losing steps. I don't really know how to solve this problem, but someone here will be able to help. Just be patient and your problem will be addressed.
    Milt
    Nov 2008
    382
    Hi there
    check your belts thats mostly the reason.
    greetings
    walt
    Quote Originally Posted by alon1976 View Post
    Hi Alon,
    What file format is the file used? True Vector (DXF etc) or Raster (BMP etc)
    I'm with the guys, it does look like a step issue but I've also seen crud on the slides do similar things.
    Before going down that road lets rule out file problems to start with.
    best wishes
    Dave
    Mar 2012
    112
    Things to check:
    1. Your belt tension. They shouldn't be sagging, but not so tight you can't push down on them.
    2. Missed steps. Run the file a few times over and see if the lines line up properly. If not, you're missing steps.
    3. Run speed. If your carriage is particularly heavy, running it too fast can cause your belts to stretch, and you end up with wobble in your lines.
    4. Gunk on your linear slides. Simple things such as sawdust, metal shavings etc stuck in the rails can create points of resistance, which in turn can lead to missed steps.
    The wobbles in the lines look like you have a belt issue, but the disconnected line on the P is a clear missed step issue.
    Build logs and other projects of mine: http://nqlasers.com/
    Probably not (i hope) but i've seen pulley's coming loose from the steppers.
    This gave similar results..
    The could rotate a little around the steppers-axis.
    Kees
    Mar 2012
    112
    Yeah, also check all the grub screws on your couplings/pulleys, they love vibrating loose over time.
    Nov 2008
    382
    Hi alan
    here is another part what has given me headache it was on the X and Y axis the idler the most have only one bearing in it I did put a second one in it, but another version is that the idler was worn out what means there was groves worn in it and this has driven me nuts till I finally found it replace the idler and who a la it works like a charme again.
    greetings
    walt
    Feb 2011
    Does this happen with all files, just this file or possibly files with fonts? I've not had the same issue with my laser but have had anomalies with vectoring from Corel files. Fix has been to create a new file if it's a simple one like text.
    Looks like a faulty motor or dirty shaft encoder..shaft encoder is a disc in the black part of the motor housing , you can pry the housing off by spreading it at the tabs in the groove and slide the housing out. Using a fine paintbrush, brush it and the reader off , be very gentle.
    Nov 2009
    314
    Hello ,
    If the lines are not straight on X aixs ,the possible reasons are as following :
    1.There is gap on X axis . Tighten the belts or fasten the screws on pulley .
    2.Check the laser head is loosening or not .Try to fasten it .
    3.Checking the beam alignment .
    4.The temperature of the water is higher .
    5.Change another fomat or graph and try again .
    Hope it could do some help !
    Mary Lee
    XYZ Mchinery
    Quote Originally Posted by EXLASer View Post
    Can you explain what watertemperature has to do with this distortion ???
    Kees
  1. Replies: 1
    Last Post: 11-08-2011, 05:30 PM
  2. Replies: 1
    Last Post: 08-11-2010, 01:59 PM
  3. convert short lines to curves
    By adscnc in forum Solidworks
    Last Post: 01-29-2010, 04:26 PM
  4. Distorted engraving and cutting
    By albo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-25-2009, 08:10 PM
  5. distorted hole
    By emergent in forum Visual Mill
    Last Post: 05-09-2005, 03:54 PM
