When we use cnc wood router to process wood panel, after engraving, drilling, we may need to cut the panel or cut the panel to several pieces. Now, you can use cnc router bits to cut wood panel, or you can use the saw with motor to cut the wood panel at more efficient working performance and lower cost, you do not have to replace cnc wood router bits often.
And when we use the saw on cnc wood router to cut panel, we may prefer the saw to cut along x and y axis both, so we can mount on 2 saws besides the spindle to cut along x and y axis, or you can use one saw, and let the saw to turn to 90 degree, then this one saw can cut along x and y axis. This is a rather good solution for cnc wood router user.
