585,987 active members*
4,436 visitors online*
Results 1 to 8 of 8
    Sep 2010
    166
    Running at max feed?
    So I finally got a carbide bit that allows me to max out my 770 at the full 10200rpm and 135ipm x/y feed. 3flute 3/8" aluminum finishing EM, 0.03" WOC, .25" DOC.
    That cut pulls only 1/2hp according to gwizard. Anything more than that and the toolholder pulls out of the tts collet. I can get similar MRRs with lower speeds, but its not nearly as fun to watch
    So anyways, now for the n00b question: is running it at max "bad" for the machine? Do you get more wear/tear/etc going 135 as opposed going 80? What about the high speed trochoidal cuts? Where the machine is concerned, is it better/worse to use those over normal milling? Or does it make no difference?
    Feb 2008
    154
    It may accelerate wear and tear but I would not be too worry. You can change the bearings anyway.
    Any video?
    C.
    Mar 2009
    1863
    I am running a 1 inch single flute Shear Hog as a fly cutter at 4000 RPM, 50 IPM and .05 DOC. Working great so far. The insert in the Shear Hog is a year old, and has never been rotated. I'm using a mixture of 25% A9 mixed with WD40 for lubricant.
    Not a big enough cut/part to worry about heat.
    I used to run the same cutter in my FADAL at 10,000 RPM, 100 IPM and a
    .200 DOC, but I had 22 HP to spin it with.
    In that case, it didn't make chips, it made chunks.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Nov 2010
    360
    I don't run max rates just to avoid possible lost steps...
    Jun 2011
    64
    2 mpm for facing and roughing operations, and I never had a problem. Of course, always with light cuts. For example with a 12 mm end mill: 4 mm DOC for plastic and 1.5 mm for aluminum. 50% engagement.
    I do not know about spindle load or HP. I use for reference the music that the machine makes.
    Nov 2004
    38
    Quote Originally Posted by dbrija View Post
    Do you ever get lost steps with the tormach?
    Jul 2007
    1602
    Quote Originally Posted by mrquacker View Post
    Have you ever read Tormach's Preventing Collet Slip?
    If you have had repeated pull out issues, your R8 collet might need replacement. It is considered a wear item.
    bob
    Nov 2010
    360
    Quote Originally Posted by andrew2 View Post
    Not that I have noticed.
  1. running emc as a simulator, running out of ideas
    By CaptainVee in forum LinuxCNC (formerly EMC2)
    Last Post: 10-13-2012, 10:52 PM
  2. Circuit for running a driver as a power feed?
    By Greenbuggy in forum CNC Machine Related Electronics
    Last Post: 02-14-2011, 01:34 AM
  3. Okuma mill feed rate jumps to rapid feed
    By easyguy97 in forum Okuma
    Last Post: 12-20-2009, 11:14 AM
  4. Hobart Handler 120 feed motor always running
    By sanddrag in forum Welding Brazing Soldering Sealing
    Last Post: 09-06-2006, 06:50 AM
  5. New table running! Q about bit feed speeds and bit durability
    By psantangeli in forum DIY CNC Router Table Machines
    Last Post: 03-07-2006, 04:52 AM
