Heads up to anyone using the new digitizing Tormach probe. Mach for some reason bugged out and smashed my tip into the work piece while probing the Z. A few months ago I notice a spindle too slow message and figured my program files might be corrupted and it's time for a reinstall. I performed a complete wipe and reinstall.
Tormach knowing I'm not under warranty, they still sat on the phone until everything was pretty much fixed/explained. All I have to say is WOW what a great professionally trained company ! Tormach is aware of the new needed information update and thought I'd post this to help them and anyone with the same questions.
What's new -
In the Tormach manual under calibrating a digitizing probe the set screws don't match the 1 2 3 screw pattern tightening sequence in the manual. After a few phone calls and testing, here's what I came up with.
Zero the first point out like stated in the manual. Now select probe point 2 and instead of locking the probe with the cable right, you would start off with the cable left first. The set screw over the cable is now set screw one, working clockwise to set screws 2 & 3.
Next you switch to the cable right, select probe point 3 in mach and hit the yellow set point by moving calibrating probe button. After all said and done, you click the adjust probe from 2 and 3 button. Adjust the screws accordingly. It took a few hours, but I was able to get every set screw to a perfect reading of 0 0 0.
