Originally Posted by
rowbare
Using an o-ring, while it will take up backlash when testing with an indicator, will likely not do anything for you when you are cutting. The spring tension has to be greater than the cutting force otherwise the spring will compress. i.e. if your axis generates 100 lbs of thrust, the springs holding the nuts apart need to be at least 100 lbs. In practice your cutting thrust will be less than maximum. If your springs are only say 20 lbs, light cuts will likely be ok but heavy cuts will show backlash effects.
bob
