585,885 active members*
6,203 visitors online*
Results 1 to 10 of 10
    Apr 2009
    165
    RFQ: 100 pieces brass disks.
    Hi all,
    I am in the need of a 100 pieces of brass cut to 4.1 mm thick discs, it also has 16 small holes that 14 of are tapped through 0-80 threads. The file attached shows the hole dimensions and location as well as the outer dimensions. The dimensions need to be pretty accurate especially the flatness.
    I am in Chicago so if there is someone local even better!
    Eric
    Attached Files Attached Files
    Apr 2009
    165
    Just to clarify all of dimensions are in mm except the tapped holes are 0-80.
    Outer dimension is 34mm the larger holes in the drawing isn’t tapped and is 1.8mm in diameter. the smaller holes are 1.2mm or whatever the drill size for cutting 0-80 threads you’re comfortable with!!! :banana:
    Feb 2012
    55
    Hello,
    What are your tolerances, for diameters, thickness, and flatness?
    What surface finish do you need?
    What alloy of brass? 360 would be lowest machining cost.
    Thanks and regards.
    Mike Schetterer
    Finegrain Metalworks
    (425) 681-4732
    Apr 2009
    165
    HI,
    Overall tolerance would need to be .01 mm for diemeter and thickness, flatness is very important as well. So the thickness could be 4.1x thick as long as its all the same. Surface finish isnt important because I am doing another operation once I recieve them. And yes I prefer c360 brass!
    Eric
    Feb 2012
    55
    Hi Eric,
    OK, but, +/-.01mm tolerance is in conflict with a 4.1x tolerance, which if I'm interpreting it correctly, means anything between 4.10 and 4.19mm, which is essentially +/-.05mm.
    Now if the diameter has to be +/-.01mm, so be it, but want to make sure you're not asking for something that adds cost, that you don't necessarily need. To extend this to hole locations, if you need +/-.01mm on the hole locations, that will be a significant cost hit, if for no other reason than the metrology needed to verify that is costly.
    Now FWIW, I would typically expect +/-.1mm on the diameter and hole locations, especially seeing as how these are mostly threaded holes. Again, you're the guy who says what it needs to be, but from a business aspect, +/-.01 is going to be a "lot" more costly than +/-.1mm.
    Just saying ...
    Mike
    Apr 2009
    165
    Here is a pic of the ones I had another guy do for me...Sadly he may not be abble to do my second run
    Jul 2012
    56
    I sent you a private message.
    BMF LLC
    Jeff
    [email protected]
    Home - BMF LLC
    Feb 2013
    Work quote reply
    I can work by drawing or sample part.
    Igs, stp, sldprt, or dxf or PDF file.
    Jack Anton
    [email protected]
    Equipment list
    Matsuura CNC Mill
    Sk M1 Cnc Mill
    Mori Seiki CNC lathe with bar feed.
    Boyer Shultz automatic surface grinder.
    Manual Mill and Lathe.
    OD grinding capabilities.
    Positioning Moore microscope.
    Solidworks Software
    Mastercam X Programming
    Bobcad Cam programming.
    3-d Machining capabilities.
    3-d Cad drafting services.
    Nov 2012
    55
    Aero-Technologies West
    Can you email me at [email protected] and i will reply with a quote. Also what kind of turnaround are you looking for?
    Aug 2007
    80
    PM with price sent
  1. A2100 Hard Disks
    By tricky in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2018, 08:33 AM
  2. Mazatrol M32 disks
    By dangreneau in forum Want To Buy...Need help!
    Last Post: 06-23-2008, 01:45 PM
  3. RFQ- Aluminum Disks.
    By Kingjamez in forum Employment Opportunity
    Last Post: 12-13-2007, 01:22 PM
  4. Divided plastic disks
    By anchornm in forum MetalWork Discussion
    Last Post: 05-22-2006, 03:41 AM
