585,763 active members*
4,408 visitors online*
Page 13 of 13 3111213
Results 241 to 251 of 251
  1. #241
    Something like that would be a LOT faster by using 2D pocketing and profiling, which would reduce the time to minutes, instead of hours. However, the extremely small features would probably not stand up to the faster operations.
  2. #242
    Mar 2011
    805
    i started with bitmap instead of vectors. i first tried to create vectors out of bitmap but result was not good enough. second step was to use aspire function to convert bitmap to 3d component and with 3d component at lease aspire does not have much options with tool path.
    is there any thing else i can do to improve the quality of carving?
    thanks Gerry for sharing your experience with this newbie.
  3. #243
    If the automated method doesn't give good enough results, than I'd create or edit the vectors manually. It takes longer, but you can get far superior results.
  4. #244
    Mar 2011
    805
    thanks Gerry.
  5. #245
    Mar 2011
    805
    Gerry, followed your advise and you are absolutely right; even for a novice like me working with vectors is pretty trivial.
    end mill marks are pretty obvious in the picuture, i was trying to see how quick machining can be done and kept overlap at 40%, hope changing the overlap/stepover stetting will take care of this issue, will find out soon. simply used one of the built in carving tool path in cam, no creativity on my part but i had to use three different cutters and getting better setting accurate z zero b/w tools.
    will appreciate if somebody can give me few pointer on how to get better polishing on wood. i want to get glass like shiny finish and want this shine to persist as long as possible. hope this does not need special type of wood. i am familiar with stains, per-stains and mineral spirit. i think on my work bench i used polyethylene (hope this is the right terminology) which gave gloss and save wood from scratches. i also experimented with wax like and liquid polish without much success. long time ago in one of tv program i watched galss finishing done on a project and if my memory is correct it was not a big deal. i think i just need right type of polish and learn correct technique. i need minimum help to get going here. thanks in advance.
    cheers
  6. #246
    Mar 2011
    805
    free stuff
    three generation old but good enough for what i want to do; on the serious note, i hear that basic features for adpbe creative suite 2 and cs5 are comparable. enjoy ...
    Adobe - CS2 Downloads
  7. #247
    You might also want to play with the "Fit Curves to Selected Vectors" tool. It will replace the automatically traced vectors with Bezier curves, for a much smoother look, and easy editing.
  8. #248
    Mar 2011
    805
    Thanks Gerry. I will try it out on my next project.
    Regards,
  9. #249
    Mar 2011
    805
    i thought this was late Christmas gift from adobe but i was wrong. i find out today that this is not a give away. i can blame vendor for putting the files and serial key on the web but this will not change the fact that sw is not free.
    Quote Originally Posted by azam1959 View Post
  10. #250
    Mar 2011
    805
    Re: XZero users group
    been a while .... regularly using machine and getting better with each project. here is the latest ... as far as machine is concerned, running like a charm. i had to replace center long screw in the beginning of 2014 and George helped me there ... cheers
    Attachment 270914
    Attachment 270916
    Attachment 270918
  11. #251
    May 2008
    4068
    Attachment 270914
    Attachment 270916
    Attachment 270918
    Nice work Muhammad, You are doing good work for just starting
    XZero cnc
  1. Twin Cities Tormach Users Group - Next meeting - Friday, November 1, 2013
    By wwendorf in forum Tormach Personal CNC Mill
    Last Post: 10-28-2013, 04:38 PM
  2. Replies: 0
    Last Post: 10-28-2013, 04:36 PM
  3. St Paul-Mpls users group
    By jkoltv01 in forum Community Club House
    Last Post: 10-11-2013, 08:11 PM
  4. southeastern vectric users group
    By cabnet636 in forum Vectric
    Last Post: 09-04-2009, 12:17 PM
