Not so fast :-)
Few things did work as I was expecting (for a change). Round over bit worked as expected. Texture also came out as I was expecting.
More things did not work out ... I thought texture will first pocket and then start texturing ... bad too assumption but now have more confidence on onsrud bit. Even cutting through 5/8 inch in hard wood, bit did not break.
Second issue ... I changed from roundover to 1/4 inch bit and jogged all three axis, touched bit to the wood piece and pressed z zero not sure why but y axis shifted.
Third issue .. text did not come out as expected. Either I used the wrong bit or may be above two issues have something to do with this error.
Good session, made mistakes and now take a step back and understand, learn and perhaps try a simpler project without texturing.
