585,604 active members*
3,282 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Toyoda HMC equipped with Fanuc 15M
    Feb 2006
    213
    I have a HMC made by Toyoda equipped with Fanuc 15M. Although machine is working fine but couple of time it's system hangs, except it's screen is ON condition, but there is no responce on operator panel, even there is no alarm message appears on the screen.
    I have replaced it's power supply unit A16B-1212-0890-01 of cnc system, but no success. There is another power supply unit A16B-1310-0010 mounted on the I/O module, that I will try to replace by later time.
    whenever system hangs, it's I/O module card IF01D, as there is 1 to 4 ER indicators are there & ER1 = red indicator lit ( See attached image)
    Kindly somebody help me or provide me IF01D fault / error indication details.
    Aug 2007
    793
    This LED indicates RAM PARITY ERROR in IF01D module itself.
    I'd advise you to replace RAM chips if it's possible.
    Feb 2006
    213
    Thank you very much for your reply, could you tell me which RAM chip's are to be replaced?
    Is it located in IFO1D module itself?
    Quote Originally Posted by guhl View Post
    Feb 2006
    213
    Smile Fanuc 15M Toyoda FN45
    Now problem appears more frequent.
    I had tried to replace power supply card of I/O module & cnc system also, but could not get rid from this problem.
    One more thing is that I suspect Base 1 memory card A16B-2200-0131/13B faulty.
    Is it possible to use Base 1 A16B-220-0130 instead of A16B-2200-0131????
    Could you also tell me that how do I take backup of the machine?
    specially Timers, counter, & keep relay data?
  1. FANUC 11m Toyoda
    By dave400 in forum Fanuc
    Last Post: 08-27-2011, 01:34 PM
  2. vmc equipped with fanuc 21 iMA
    By rai in forum Fanuc
    Last Post: 03-19-2010, 02:57 AM
  3. Replies: 5
    Last Post: 04-17-2008, 02:44 AM
  4. Fanuc 16i and Toyoda
    By RAC in forum Fanuc
    Last Post: 10-27-2006, 01:28 AM
  5. Fanuc 16i and Toyoda
    By RAC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-19-2006, 01:48 AM
