585,759 active members*
3,985 visitors online*
Thread: Die Blocks
Results 1 to 6 of 6
    Aug 2008
    405
    Die Blocks
    Could I please get a quote for these 3 details / Thanks
    Attached Files Attached Files
    could you tell us the quatity and material?
    Brant
    [email protected]
    ADVANCE TEAM COMBINE HK LIMITED
    Aug 2008
    405
    The material is a-2 hardened I need one of each .Thanks
    what model of the stell for the material?
    but for 1 pc, it's not a good way to use die cast method, (need to consider the die cast mold cost)
    directly machining and then heat treatment to match your require hardness is more cheaper.
    Just my personal idea.
    if you have any question, send me email.
    Brant
    [email protected]
    Aug 2008
    405
    Come on guys this is simple stuff get a piece of A-2 OR D-2 toolsteel grind it flat drill wire start holes drill mounting hole drill and tap jack screws put it in the oven heat treat it grind it flat after heat treat
    then wire the openings....And no one can give a quote to make one of each...Plus minus one on all dim is fine.....
    Quote Originally Posted by gabedrummin View Post
    please send your detail drawing and quantity requirement to us e-mail:[email protected]
    Dawopu Group
    Web : Dawopu Group We never forget who we're working for
    E-mail: [email protected]
  1. Replies: 17
    Last Post: 08-29-2012, 05:06 PM
  2. BPS (Blocks Per Sec.)
    By steve cline in forum Mastercam
    Last Post: 10-24-2011, 05:06 PM
  3. BPS (Blocks Per Sec.)
    By steve cline in forum Haas Mills
    Last Post: 10-19-2011, 05:10 PM
  4. 100 mm set up blocks
    By LEARN in forum CNC Tooling
    Last Post: 08-09-2011, 05:53 PM
  5. end blocks
    By john86126 in forum Linear and Rotary Motion
    Last Post: 04-29-2008, 02:57 AM
