Dear all, I built a cnc machine using rack and pinion mechanism for x and y motion.
I use mach3 as a controller softwre, and the same settings were given to x and y axis.
The y axis works great and precise.
The problem is in the gantry (x axis), it is powered by two motors.sometimes it works great and other times the traveled distance is less by 3mm.
Each side of the x gantry is driven by a motor, and the rack at each side is formed by two pieces : one of length 1 meter and the other is of length a half meter.
Are the motors weak and i need powerful motors or the two rack pieces are not well aligned?? Any suggestion is really
appreciated.
