585,708 active members*
3,759 visitors online*
    Nov 2010
    56
    milltronics cent 6
    does anyone have a cent 6 post for partmaker
    Jul 2010
    548
    partmaker post.
    If this is for your P3 C6 control try a genaric FANUC M6 or M10 post. it should be ~ 99.9% complete The one major difference between a FANUC post and a Milltronics is the way ridgid tap works. Fanuc is G84 and Milltronics is G88. Milltronics uses the G84 as a "soft tap" cycle. before ridgid tap became "afordable" Milltronics developed the "soft tap" cycle. It is an algorithum used to do tapping with out the dirrect encoder feedback. Works pretty well but is based on a 220V input. if 208 then it runs slow, if 240 it runs fast. so "tweeking" of thee spindle drive parameter "max spindle freq" is needed to be accurate.
    sportybob
  1. will Cent 5 simulator run on WIN 7?
    By chipsinpan in forum Milltronics
    Last Post: 04-09-2012, 04:23 PM
  2. What DNC program to use for Cent 6?
    By RobT in forum Milltronics
    Last Post: 06-21-2011, 01:46 PM
  3. Milltronics VM16 Cent V
    By muttley69 in forum Milltronics
    Last Post: 05-03-2011, 07:15 AM
  4. Replies: 8
    Last Post: 11-15-2007, 06:16 PM
  5. cent 6 I/O
    By HANSENTECH in forum Milltronics
    Last Post: 12-03-2006, 11:27 PM
