585,974 active members*
4,523 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > What motor will suit Fagor Drive
Results 1 to 10 of 10
    Jul 2003
    1220
    I have a 3 axis machine centre with a Fagor 8055 controller, which I am wanting to add a 4th axis (A)
    I have acquired a Fagor AXD servo drive with Output 3 X 0-460AC, 8amp max, 0-800hz.
    I am now looking for a servo motor which will run with this drive.
    Do I need to use a Fagor brand or will other makes run OK?
    If so, what specs do I need to check, phase/voltage/hz/etc ?
    It is better to use the original Fagor motor to get the best performance, or change the motor and driver all with other brand.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jan 2006
    2985
    You need an AC servo motor. It needs to be 400V class. The feedback device needs to match what the drive is expecting. If the drive accepts a standard signal (like quadrature encoder) then almost any old servo motor should work with it, assuming the drive has a good way to change the parameters to suit the new motor.
    Lots of cheap servos on ebay, not so many with 400V rating.
    Good Luck
    Matt
    Jul 2003
    1220
    Thank you for your help.
    I purchased a motor from ebay that I hope to get to run.
    Allen Bradley Servo Motor MPL-B220T-VJ44A With Brake 460VAC 3 Phase 3.3A
    Not sure about the encoder, I believe (with my limited knowledge) the Fagor will handle sine-wave or resolver.
    The Fagor has about 60 parameter settings, so I'm hoping to get them to match.
    24221
    AB is usually resolver, It may be OK as long as the resolver excitation is compatible?
    Al.
    Albert E.
    Jul 2003
    1220
    The motor specs show 'Multi-turn High Resolution Encoder'
    Google search describes as:
    Multi-Turn Encoders...are absolute encoders that also measure cumulative rotation.
    The motor label shows: Freq 0 - 400 hz. when the driver is 0 - 800 hz. Is this going to be a problem?
    I have a lot learn.
    Jan 2006
    2985
    The driver is capable of up to 800 Hz. The motor only requires up to 400Hz for max speed. No problem at all.
    Matt
    24221
    For an 8 pole motor, which it most likely is, that would give you 6000rpm at 400Hz.
    Al.
    Albert E.
    Jul 2003
    1220
    That sounds good, the motor is rated as 6000 rpm.
    Sep 2010
    1765
    if Al is right about the ab drive taking resolver feedback, it does not matter if output frequency of drive is ok or not: your motor being absolute encoder feedback will not work with it. most likely you have Heidenhain Endat or Biss or Stegmann or SSI or gray code absolute encoder. An absolute encoder is not a resolver. you need to know if your drive can accept the specific type absolute encoder your motor has first.
  1. Setting driver amps to suit motor.
    By Simon C in forum Stepper Motors / Drives
    Last Post: 08-11-2021, 12:57 AM
  2. Drive Error with Fagor 8055M
    By Kiwi in forum Fagor Automation
    Last Post: 08-06-2012, 09:53 AM
  3. Fagor 8025TG replacement drive problems
    By pirates712 in forum Fagor Automation
    Last Post: 08-01-2011, 05:29 PM
  4. which gecko drive isbest suit for this motor
    By rexroth in forum Gecko Drives
    Last Post: 03-05-2007, 03:34 AM
  5. Reliance Electric 1326AB-B430E-21, any servo drive to suit this?
    By Splint in forum Servo Motors / Drives
    Last Post: 10-21-2006, 04:41 AM
