584,800 active members*
4,443 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need some help with fanuc-ot 900 parameters lathe Colchester CNC-3000
Results 1 to 6 of 6
    Jul 2012
    Hi all,
    I lost the parameters 900 and I haven´t datasheet of COLCHESTER CNC-300 with Fanuc OT.
    The old factory change and now they tell me that haven´t the datasheet.
    They gave me this parameters.
    Parameter + / - 7 6 5 4 3 2 1 0
    N0900 0 1 1 1 1 0 0 0
    N0901 1 1 1 1 0 0 0 0
    N0905 0 0 0 0 0 0 0 1
    N0907 0 1 0 1 1 0 0 0
    N0909 0 0 0 0 0 0 1 1
    But they are not sure they are compatible.
    The problem is that all works well, but the spindle that not run.
    If anyone have this parameters I appreciate it very much.
    Many thanks.
    Talleres Garsu, S.L.
    Jan 2011
    350
    PM sent.
    I'm guessing you had all the regular parameters & data diagnostics punched out in backup and you only forgot to write down your 900 parameters manually. Don't forget to write it down this time.
    Mar 2010
    Re: Need some help with fanuc-ot 900 parameters lathe Colchester CNC-3000
    Hello everybody!
    Sorry it's old post, but i'm in trouble, i have lost all the parameters. Could anybody help me it's Colchester 3000 lathe with fanuc-ot? Thank You!!!
    Dec 2008
    3110
    A link to Colchester 2000L list.....it may help
    May 2016
    526
    I have a set
    Aug 2013
    Hello MB Service
    i have a lathe machine wassino with O-T Fanuc, i did backup the parameters and diagnostics parameters, i had to do a clear all memory and now i should enter the 900s parameters to be able to connect the RS232 to restore parameters.
    can you help me and explain to me the 900's parameters how it looks like?
    as example for diagnostics its starting with N10300, for regular parameters it's starting with N0001 but it's stopped at N0879 and continue with N8100 to N8399, do you have any idea if my 900's are available? and if not what do you suggest?
    thanks
  1. PARAMETERS FOR COLCHESTER 3000L WITH FANUC OTA
    By raymond.baker8@ in forum Fanuc
    Last Post: 09-01-2023, 02:16 PM
  2. Fanuc OT Control/Colchester 2000L Lathe
    By okhan in forum Fanuc
    Last Post: 12-15-2020, 10:06 PM
  3. colchester 3000 parameter
    By ahmedrehan in forum Colchester Tornado lathes
    Last Post: 08-29-2012, 02:36 PM
  4. Lost PC Parameters (3000 - 4021) Fanuc 6Mb
    By tubby735 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-29-2011, 04:07 PM
