585,894 active members*
5,029 visitors online*
    Sep 2005
    287
    Un-install & re-install changes Mach3
    Hi All,
    I'm messing with 2 versions of Mach3 - 3.42.020 & 3.042.029
    A plasma cutting plugin is installed once Mach has been installed. For certain reasons I've been un-installing Mach / plugin then re-installing to the other version of Mach.
    I noticed the THC (torch height control) button was not working. This is a toggle button with an LED to go with it. I checked on another computer which had recently had the very first install of Mach and the THC button worked fine. I un-installed Mach on this computer then re-installed and the THC button did not work any more. So I've managed to repeat this problem on two independant computers.
    It seems the un-install and re-install of Mach3 is corrupting something. I am now going to format the drive on my workshop computer and re-install XP. If this issue is repeatable then in my case an un-install of Mach3 means a re-install of XP just for Mach to install correctly.
    Another point of note is that when I re-installed Mach3 (no plugin install yet) I opened the plasma profile and the THC button would not work (just in case the plugin is being blamed).
    Anyone got any ideas ??
    Cheers,
    Keith.
    Sep 2005
    287
    Self solved - had to re-enter my Mach3 license, no THC in demo version.
  1. Xbox controller install on Mach3
    By zeeway in forum Mach Software (ArtSoft software)
    Last Post: 01-19-2020, 02:24 AM
  2. Mach3 New Install MDI Screen Pressing X Jumps to DRO
    By cjjonesarmory in forum Mach Software (ArtSoft software)
    Last Post: 12-21-2011, 06:31 PM
  3. Need help to install plugin to Mach3...
    By jaru-eri in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-28-2009, 05:46 PM
  4. Install help
    By djmickyg in forum LinuxCNC (formerly EMC2)
    Last Post: 12-02-2007, 03:05 PM
