Im having an issue with the siemens 828d control running a 4 axis mitseiki cv-2000 vertical machining center. Ive had a mastercam rep out to write a post for me which all seems to be working fine. there is an issue with the control where it is not giving me continuous path. G64 is the code to activate this but it doesnt seem to make a difference. a simple 2d contour path seems to stop at the quadrants when rolling around a 90 degree corner.
i replicated this toolpath in shopmill directly on the controller and it does the same around a 90degree corner. ive had a technician out who services siemens and even he cant work it out.
I need help urgently as this seems like such a basic thing but no one knows how to fix it. If anyone has the same control or can direct me to someone who has the same control that would be great.
