585,744 active members*
4,901 visitors online*
    Aug 2012
    4x8 APC issue
    Howdy everyone...I'm new here and this is my first post. I have had my table a couple of months and recently have a problem that has all ways been there, but now it is an issue with some of the parts I cut.
    When cutting a "slit" the torch arc does not turn off at the end of the cut. The arc stays until the torch height becomes high enough for the arc to go out. On thicker material it is not so bad since these slits are there to allow me to bend the part without a press brake. On thin material parts these slits are usually a detail on the art work or something like that.
    My question: How do I make the arc turn off at the end of the cut, not as it is retracting up? With the arc still on as the torch move up, it burns a LARGE hole at the end of the cut....
    Unfortunatly I work a full time job that does not allow me to call tech support at ez Router. I called the other night and told them when I could be reached, but no return call....
    Jun 2012
    5K Fabrication
    The function control knob ,on the front of the unit, is set to the wrong setting! Turn the knob to the "Run" setting! This is the top right setting! The switch should be set to about 2 o'clock!
    Thank You,
    Jonathan Champang
    Ez-Router Tech Support
    [email protected]
    Aug 2012
    Thanks Jonathan.
    It was on the wrong setting. I ran a couple of simple programs and seems to work OK now.
    Karl
  1. Cambam issue or Mach 3 Issue??
    By tracyranson in forum CamBam
    Last Post: 07-11-2011, 04:03 PM
  2. will this be an issue?
    By stk2008 in forum Stepper Motors / Drives
    Last Post: 09-17-2009, 04:35 PM
  3. New to CNC, G52 issue
    By andywids in forum G-Code Programing
    Last Post: 01-10-2009, 07:09 PM
  4. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
  5. THC Issue
    By Aldoseri in forum CamSoft Products
    Last Post: 01-31-2006, 11:33 AM
