As a CNC Fusion user, i can say you are going to want to tighten that 12mm Z Axis bracket securely. Also consider doing the Z modification to allow reaching the gib screws. Check my X2 thread for a link to the source. Recently, I've had a problem with the Z motor mount moving. Even putting 3 extra bolts ini didn't stop it. I'm nursing it now but need to figure out a permanent fix.
Other than running an end mill into the table or a fixture or clamp, not having home and limit switches are not a problem. I just added home switches last month after several years of hard use. So, as the say, "just use it"!
Cheers,
Michael
Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
www.EclecticAngler.com | www.ReelLinesPress.com
