585,752 active members*
4,110 visitors online*
    Aug 2012
    Cam grinding?
    Ive been lurking around looking at build threads since I found one of these motors on YouTube. I want to build a small simple single or maybe two cylinder. Question is how do you guys grind your cams?
    Jan 2007
    76
    You can machine most of the material away with a milling machine and then "round-off" with a hand file.
    I made a machine to grind cams but some will say "it'll never work" and go into vast theory as to why not.
    However, the cams are simple and the 4 cylinder engine (25cc) it is installed in will run up to 10,000 rpm. Quite a satisfactory result for me.
    Have some pics of the grinder somewhere if you are interested.
    Jan 2007
    76
    Found the pics of the grinder.
    Have started to build a "parallel tracking" grinder to do vintage motorcycle cams. More acccurate approach for these.
    Also, these couple of sites should help.
    http://modelenginenews.org/techniques/meek_cams.html
    http://modelenginenews.org/techniques/camgrind.html
    If you go back to just the "techniques" in this web site, it opens up a vast array of information.
    Attached Thumbnails Attached Thumbnails 100_0295.jpg   100_0296.jpg   100_0297.jpg   100_0298.jpg
    Dec 2006
    603
    I make my camshafts in the lathe using a fixture. Read this for more info.
    camarticle
  1. OD grinding
    By Mike G in forum Community Club House
    Last Post: 05-21-2010, 04:41 PM
  2. I.D. Grinding
    By heavy metalmach in forum Employment Opportunity
    Last Post: 03-19-2008, 10:42 PM
  3. cnc grinding
    By invs879 in forum MetalWork Discussion
    Last Post: 03-03-2008, 08:23 PM
  4. Grinding
    By krismcneil in forum MetalWork Discussion
    Last Post: 05-03-2007, 02:06 AM
