I have upgraded to rhino 2012
I have used rhinocam 2.0 standard for many years.
I have upgraded to rhinocam 2012 standard, and also upgraded my PC to get more calculation power so I have started using more 3 axis machining.
It seems to me so that I constantly run into problems (errors).
3 axis roughting: Clear flats. Not all flats are found.
3 axis horisontal finishing: Clear flats find all flats i hole part. (known issue). But optimize machining between levels not alwas clear all flats in region.
3 axis horisontal finishing: Sometimes the path machine a area in lower z level first, that causes damage on part and machine.
The problem is for me that I can't trust that all geometri is correct machined. I use a lot of time with the simulation, and control of what levels are machined first.
I also find a problem with the new tabs feature. Sometimes the tabs are missing, and sometimes they are very wide.
I can't fint the multiply core manager in the program. One of the reasons why I opgraded.
Are there others with same problems?
