I picked up a 1986 Mazak Quick Turn 20n a few days ago and just managed to get power to it this evening.
Much to my surprise.....the control booted up and the hydraulic pump created a small fountain in the front of the machine where the Hydraulic steady rest used to reside.
So I began to go through the procedures outlined in my parameter manual to reset the parameters since they were all out of whack.
I know nothing about this machine or control......so I may just be doing something wrong. I have a service bulletin and a parameter list with instructions on how to reload them.
When I try to begin changing the parameters by typing then pressing input......nothing happens.
There is a message on the input line that say "Return Home?" I don't know what to do with that....lol.
I followed the instructions about "if control refuses to let you change parameters"......Type in 1CB706....press input......but then it says to set the hex data associated with this to the value on the parameter sheet.
I cannot find this......the manual further says its usually 00 or 08. I tried both to no avail.
It says after doing this I should be able to clear memory. Is that another step, or should I just be able to change each parameter?
Where is the best place to find manuals about this machine?
Mike
