585,927 active members*
3,513 visitors online*
Results 1 to 8 of 8
    parameter of (fanuc o_m) is here
    fanuc o_m parameter )
    Attached Files Attached Files
    24221
    For what machine??
    Could be for any MTB?
    Al.
    Albert E.
    parameter
    this is only o_m controler>>>>>>
    Aug 2011
    2517
    yes. but for WHICH machine?
    what is the make and model of the machine that these parameters came from?
    parameter
    VMV 500B
    MODEL SEP 90
    CNC UNIT MODLE IS FANUC OMF
    parameter
    MACHINE NAME IS KRYLE>>>>>>>
    Hello,
    machine is kryle 500b, GE Fanuc OMF
    problem with ATC, only thing that machine does is move to home and orient spindle, alarm says failed to index is one, other alarm is failed to move foward/retract.
    macro seems to be done right, parameter 240 bit 0 is set to 6, programs are O9001 and O9003, if someone can reply with a list of thing to put in a post I can give better decription. Is there a tool home and how is it done?
    Jan 2021
    Re: parameter
    Can you send me o_m parameters
  1. Parameter for using G68 on Fanuc 11M
    By 4thaxismachine in forum Fanuc
    Last Post: 01-02-2024, 03:47 PM
  2. FANUC 6T PARAMETER
    By hiiesalu in forum Fanuc
    Last Post: 01-23-2013, 08:33 AM
  3. Parameter for Fanuc OI-MB
    By CBMach in forum Fanuc
    Last Post: 06-26-2012, 11:39 PM
  4. FANUC 6T PARAMETER
    By J.R. SWIGER in forum Fanuc
    Last Post: 07-12-2010, 08:18 AM
  5. Need help with Fanuc 6MB parameter
    By nguyenthanhthi in forum Fanuc
    Last Post: 10-22-2007, 02:12 AM
