Who used the 4th axis on the 6040 yet?
Where best to mount it?
Any good way to remove the table and mount the A-axis at or below Z=0 to get maximum Z-travel?
Any cheap software that does not only do 3 axis milling in X+Z+A makes use of of the Y axis to e.g. follow the surface normal?
Any way to transform an STL object, so that a 3 axis CAM software can work with it, thinking A would be Y ?
