I'm having trouble opening up a milled slot using the Y,Z axis on the machine. I'm using parts maker software and cutter comp, it does not seem to matter how much I comp the radius it does not change the width of the slot. I'm using a 1/4 carbide end mill, in a .406 wide slot. I tell it to compensate left but the post comes out with a G42 and rotates using C axis. I've even tried offsetting in the model and it still does not work. I over travel if I use the X axis, any suggestions?
