585,956 active members*
4,257 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Trying to wire up a Delta Servo Drive
    Jun 2006
    82
    Hi guys,
    I have managed to get a few delta servo drives and motors but a little overwhelmed by all settings needed to get the drive to work with Mach 3
    Drive spec:
    asd-a0721-ab
    AC servo drive
    A series
    750w output
    220v single phase input
    2500ppr encoder resoloution
    Supports ECMA series servo motors
    I have a PMDX 126 and have worked out I need to output step to CN1 pin 37 (sign) and direction to CN1 pin 43 (Pulse)
    I am guessing that i also need to set the perameters to have the drive accept step and direction commands as well as the setting to keep the drive work without burning out.
    I will admit that so far I have only used steppers so just need a bit of push in the right direction to get these servos working!
    Jun 2006
    82
    drive data sheet
  1. Replies: 2
    Last Post: 06-23-2014, 07:59 AM
  2. Delta Ac Servo ASD-B2-0721-B
    By ecortech in forum Servo Motors / Drives
    Last Post: 03-26-2012, 02:33 PM
  3. Delta ac servo
    By ecortech in forum Automation Technology Products
    Last Post: 03-24-2012, 06:23 PM
  4. Delta VFD Drive
    By rrbmachining in forum Phase Converters
    Last Post: 05-01-2011, 02:28 AM
  5. Delta tau nc2.36 servo error
    By JR1050 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-02-2009, 05:59 PM
