How much blocks from buffer CNCs 6MB an 0MA process to calculate the toolpath?
Other words, when the work surface will be better, when cut on 6MB or on 0MA?
regards
regards
the machine buffer is usually 3 lines of code (i.e. the machine pre-reads 3 lines ahead of the current line). however there are options available to give the machine a larger buffer if that is required. the number of steps of the servo can also affect the smoothness of the path. usually the newer servos (newer technology) give a smoother work surface but it can depend on exactly what hardware/software is fitted to the machine. 0M is newer technology so I'd go with that.
