585,997 active members*
5,150 visitors online*
Thread: Gorton 3 Z
    Jan 2007
    17
    Gorton 3 Z
    I need to make some pockets for inlays in stainless & nickel silver from .050 t0 .125 deep, do you think it can be done with a Gorton 3 Z pantograph, is it ridged enough for this ? it is tight and in great shape, I know there better things to do this with but this is easy to come by. Thanks
    The 3Z is one beast of a machine and in my opinion well capable of the task.
    (As I am sure you are well aware, when working with stainless coolant must be used to prevent any heat build up in the work piece else the working edge will harden and dull the cutter in no time).
    Tweakie.
    CNC is only limited by our imagination.
  1. Gorton 3-48 Milling machine
    By dougputt in forum Uncategorised MetalWorking Machines
    Last Post: 01-03-2019, 04:14 PM
  2. Intro & Gorton I-22 CNC Conversion
    By EmeraldIsleforg in forum Vertical Mill, Lathe Project Log
    Last Post: 06-22-2012, 02:53 AM
  3. Gorton Tool Grinder
    By JKENIK in forum Uncategorised MetalWorking Machines
    Last Post: 10-16-2010, 09:56 PM
  4. Gorton 2-30 ready for CNC project
    By paulmars in forum Vertical Mill, Lathe Project Log
    Last Post: 11-27-2008, 07:47 AM
  5. Is $900 too much for a Gorton 8D mill?
    By Stuff-Builder in forum Knee Vertical Mills
    Last Post: 07-31-2008, 10:36 PM
