585,978 active members*
4,438 visitors online*
    Oct 2005
    40
    Need help with deskcnc
    I need help with deskcnc does any body have some tutorials for a lathe and mill Also some sample machine setting and programs. I was able to turn and mill some Parts by using basic g codes with a text editor. I am having trouble turning a radius on A face of a shaft I tried G03 with an R doesn’t work imservice is not much help They said try G18 IJK. They are working on a lathe tutorial .Also I could use some Post setting. I bought this to have. Some fun with. I tried using my teksoft cad cam software at work that I use on my turning and milling center it works close. But I would like to use deskcnc. I am using a sherline lathe and mill with a rotary table. Any information would help.
    270
    For DeskCNC support and help, you may search and post on the user's forum at :
    http://www.imsrv.com/discus
    There is a book called "Easy CNC" on using the image and DXF format files for milling.
    Fred Smith - IMService
    http://www.cadcamcadcam.com/hobby
