585,759 active members*
4,058 visitors online*
Thread: CMOS Battery
    Nov 2005
    111
    CMOS Battery
    Hi ,
    I use a Bridgeport ExTrak CNC 2 three axis milling machine . It works some years without problem , but now I get the message CMOS Battery failed . Does someone knows where I can find the battery ? I do not find the battery on the pc-board.
    Hans
    May 2004
    4519
    Might look like this:
    Nov 2005
    111
    Hi TxCncMan ,
    many thanks for your answer I did not think that the battery is solderd in and I have no chance to change the battery .
    Hans
    Jun 2007
    129
    If your EZ Trak is a 1998 or later, it will have the single board computer with the timekeeper chip. Some of them were socketed which makes an easy change but if not, find someone who is good at repairing circuit boards and have a socket installed. The timekeeper chips are cheap. Amazon sells them for about $16.
    Nov 2004
    3028
    If you search this forum, this topic will come up many times.
    The problem is that we do not know what is inside your electrical cabinet. It could be an original mother board with a NiCad battery soldered in, or a coil style lithium on a newer board, or a Dallas Real Time Clock chip as mentioned before.
    post a picture of the control part of yor electrical caand we may be able to help you.
    George
  1. Eztrac CMOS battery
    By Neil Mckillop in forum Bridgeport / Hardinge Mills
    Last Post: 05-10-2012, 02:41 PM
  2. CMOS battery
    By APinSoFla in forum Milltronics
    Last Post: 02-15-2010, 04:25 PM
  3. Fadal CMOS Battery Replacement
    By RoboVin in forum Fadal
    Last Post: 12-09-2008, 11:31 PM
  4. Partner 1 rev G machine CMOS battery low
    By life3970 in forum Milltronics
    Last Post: 02-07-2008, 10:38 PM
  5. External cmos battery?
    By MegaMoog in forum Bridgeport / Hardinge Mills
    Last Post: 10-30-2006, 01:51 AM
