585,581 active members*
3,786 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Parameters for Bridgeport Series II Interact 4 TNC 155
Results 1 to 7 of 7
    Aug 2012
    Does anyone have the parameters for a Bridgeport Series II Interact 4 TNC 155 and does anyone know where to find a service manual?
    Nov 2009
    13
    I'm experiencing the same problem, I lost the parameters of my interact 4 series II with TNC155, if someone have these parameters I'm interested as well! Thanks
    Srussel, if you mean the Bridgeport manual, I'll start to scan mine tomorrow, if you need a specific information don't hesitate to ask!
    François
    Sep 2011
    30
    Nov 2009
    13
    Scan completed, you can download the pdf of the maintenance manual with this link:
    Bridgeport interact 4 series II Maintenance Manual
    I hope it can help.
    François
    Aug 2012
    Thanks for the manuals. They both will help alot.
    Nov 2009
    13
    Here's a copy of the parameters the previous owner of the machine sent me last week, limit switches need to be adapted (procedure described in the mill's manual) and a few others to your preferences.
    I had an issue with the x axis which would overtravel after the limit switch, it was fixed by Gridley51 (once again) by changing the parameter 20 from 1 to 0 (counting direction).
    The maximum speed is set at 3750 in these parameters but should be 4000.
    Except these things my mill (interact 4 series II with tnc 155b) works as well as before losing the parameters, so it should be ok for you too.
    Good luck.
    François
    Re: Parameters for Bridgeport Series II Interact 4 TNC 155
    Dear Francois,
    A couple of years ago you posted link of a manual for an interact 4 series 2, but that link is not working anymore.
    I have the same machine, but no manual.
    Would it be possible to put it online again,
    Regards,
    Manuel
  1. bridgeport interact 1 lost parameters
    By thomasmc in forum Bridgeport / Hardinge Mills
    Last Post: 02-02-2015, 10:35 PM
  2. Bridgeport Interact 412/Heidenhain TNC 250 initial parameters
    By pedrow in forum Bridgeport / Hardinge Mills
    Last Post: 09-26-2014, 08:11 AM
  3. Bridgeport interact 1 mk2 heidenhain tnc 370 parameters needed
    By eren afacan in forum Bridgeport / Hardinge Mills
    Last Post: 02-21-2014, 05:36 PM
  4. Bridgeport series 2 Interact 4 With Tnc 145 Parameters needed
    By Angoraracing in forum Bridgeport / Hardinge Mills
    Last Post: 03-01-2012, 04:52 PM
  5. Bridgeport Interact 720 parameters
    By M.G.Machinist in forum Bridgeport / Hardinge Mills
    Last Post: 01-08-2010, 01:04 AM
