585,996 active members*
4,222 visitors online*
Thread: IPM Alarm
Results 1 to 9 of 9
    Jun 2003
    70
    IPM Alarm
    Daewoo 300 Puma Lathe Fanuc 21T has 449 Z-axis INV IPM alarm in winter only. Works fine during the summer. In winter machine must be on for an hour in order to clear alarm. Anybody had this happen to them before?
    Jim Short
    www.tahlinc.com
    Feb 2009
    6028
    What # does the drive display? Sounds like a fan going out.
    Aug 2012
    12
    Hi
    Not sure if you know this or not but the Ipm alarm is usually caused from servo amp transistor module. With problem only in winter I might look into moisture/corrosion on transistor screw terminals aswell as make sure they are tight. The latter is only common with refurb/repaired units. Hope this helps, apologies if not.
    Jun 2003
    70
    Quote Originally Posted by underthetire View Post
    The drive shows 8.
    Jim Short
    www.tahlinc.com
    Jun 2003
    70
    Quote Originally Posted by seikicnc View Post
    Hi
    How do we identify the transistor module?
    Jim Short
    www.tahlinc.com
    Jun 2004
    511
    The transistor modules are big black blocks in the back of the unit.
    Dec 2008
    239
    Check The Fan . Inside the Drive .The regenerative Circuits. Also the earth Pit of the machine . The Ground cable. The breaking of Drive . Torque Setpoint.
    [email protected]
    Check out the section of the Fanuc maintenance manual.
    Attached Files Attached Files
    Jun 2003
    70
    Solution: Replaced Z-axis drive. All is well.
    Jim Short
    www.tahlinc.com
  1. Replies: 27
    Last Post: 02-09-2022, 05:10 PM
  2. Replies: 4
    Last Post: 05-03-2019, 08:58 PM
  3. Replies: 6
    Last Post: 04-29-2011, 11:20 PM
  4. Alarm 409-servo alarm- z axis torque alm
    By jessebpm in forum Hyundai Kia
    Last Post: 06-15-2010, 01:45 AM
  5. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
