Originally Posted by
darkeagle10x
I have a 1995 HAAS VF-2 and tried doing text using G47 and get invalid G code.
Is my machine too old for this code?
Dan
if your machine is previous to dec 1995 then the code won't work on your machine , haas allows for custom built g codes , so if your machine is setup to run macro then you could build your own g code with individual sub routines for each letter , that's basically all the g47 is , along with a bunch of if's and's or but's , If you program all of your letters to 1" then you can use the scale function and a variable to size it to whatever you want , it would be a fair bit of work but once your done you'll always have it .
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
