hey guys how are you
a customer told me that he has two wire edm machine that can't work because the
electrical circuits was damaged and also the control system as well
and here is the point its my first time to interface mach 3 with these types pf
machines but i started my work
searched for many programs first that can generate the 4 axis g code
x,y,u,v but there is some fault because the programs i fount cant generate the
g code for two faces or complex faces like HF software for EDM wire machines
came from china so will any one help
the software i found was
1-foam works
2-desk cnc
3-heeks cnc
also i want to build my mach 3 screen for this work i downloaded the screen
designer but is there is any PDF that can explaine these tools in details
i have a lot of questions but i am waiting for any answer
* i believe in mach 3 that why i converted my fanuc milling machine into mach3
controlled machine *
