Hi All,
I have a home built CNC Router which I bought a couple of years ago. I do not use it very often. It is not the best or the fastest in the world, but it worked, or at least it used to.
It started to cut random arcs where no arcs are coded. That is, if I am cutting a shape, perhaps with 6 or 7 runs to complete the full shape, it will cut some runs as coded, but other cuts will produce a small arc somewhere, even though the code for the arc has not been in the original drawing. I have checked for extra layers in the drawings.
Mostly, these arcs will even appear on the display screen while they are cutting. When it starts to cut one of these mystery arcs, then it will follow the same track when it cuts that arc again, within the same cutting run.
Occasionally, the arcs will appear, but as full circles, after the code is loaded and before the cutting starts. This happens only on the XP, not the Windows 7 computer.
The drawings are coded via CamBam, using a Windows 7 computer. The NC Files are always run through Mach3 on the Win 7 computer, then taken to the Windows XP computer attached to the Router when they have been run successfully.
I purchased a refurbished XP computer, (no Mach3), then installed Mach3 on it, but the arcs still appear when a file is cut.
I can't try the Windows 7 computer on the Router due to no Printer port.
Thinking it might be the Router electronics, I have disconnected the Router from the XP, then run the various NC files, but the problem remains.
I am at my wits end with this. I have not been able to make a complete accurate cut for quite a while, so I am just wasting material.
If anyone has any idea what could be causing this problem, I would very much appreciate hearing about it and trying it. It will help to save the sanity of another Oldie who loves the idea of CNC Routing.
Thanks in advance,
Albert
