585,914 active members*
3,897 visitors online*
Thread: tabs
Results 1 to 8 of 8
    May 2012
    tabs
    Hi...I'm making progress with my first CNC project. I'm cutting cabinet parts out of a 4 x 8 3/4 cabinet grade plywood. I'm having some problems removing the parts from the 4 x 8. I've been using a sharp chisel to break the tabs. But this occasionally damages the cabinet part. I've tried using a Dremil tool but that process is very slow. Is there a better way?
    Mazzy
    Apr 2007
    8082
    Quote Originally Posted by mazzy View Post
    Mazzy
    Dremel makes a router base for the older 200 series Dremel Tools. Try one of those and use a RotoZip blade that cuts on the side and end. Dremel also sells a carbide tile ceramic tile cutter with the diamond shaped part long enough to reach over 3/4" deep. With the router base you can set the blade depth and just slide it over the tabs to cut through them.
    CarveOne
    http://www.carveonecncwoodcraft.com
    May 2012
    Dremel parts
    Thanks...Home Depot has a large assortment of Dremel accessories. I'll check them out.
    USe a laminate trimmer and flush trim bit to route them off.
    How are you holding down your sheets?
    You may find that if you leave a thin onion skin instead of tabs, that it's easier to remove. Tabs would be my last choice.
    May 2012
    tabs
    Thanks Gerry,
    How would I create a thin onion skin?
    May 2012
    tabs
    Gerry,
    Regarding holding down my sheets I have a double 3/4" MDF. The top MDF is the spoilboard. Using drywall screws I hold down my work piece with screws around the outside edges so my bit will miss them. I've thought of using the Raptor setup but their nail gun ($300) is a bit pricey for my right now.
    Mazzy
    Apr 2009
    5516
    Like Gerry says, use a trim router and a flush trim bit. Porter Cable makes a 1/4" flush trim bit that would work well. If you use tabs, then try to put them in a less conspicuous spot if possible.
    May 2012
    tabs
    I tried a trim router and it works great!!! What was taking me 1/2 hour with the Dremil is now taking me 5 minutes. Thanks for the suggestion.
    Mazzy
  1. RFQ shackle tabs
    By Redgoatfab in forum RFQ (Request for Quote)
    Last Post: 01-10-2012, 04:33 AM
  2. Tabs - Again
    By Magnum164 in forum SprutCAM
    Last Post: 02-21-2011, 03:50 AM
  3. Tabs in V24 Pro (how to)
    By tome9999 in forum BobCad-Cam
    Last Post: 02-03-2011, 12:53 AM
  4. Tabs How and Where?
    By Mr.Chips in forum Uncategorised CAM Discussion
    Last Post: 03-04-2008, 03:08 PM
  5. Tabs in V9
    By MikeA in forum Mastercam
    Last Post: 03-21-2004, 12:55 AM
