585,933 active members*
3,816 visitors online*
    Apr 2005
    253
    4 axis screen set not displaying correctly
    Hi all,
    I have completed my 4 axis foam cutter build and have downloaded the Sam Harbold 4 axis foam cutter screen which displays on my netbook ok but on my cnc computer the bottom portion is displayed off the screen, see pic attached.
    I have the pc at 1024x768 and it displays the fantastic 2010 screen set by ger21 no problems.
    Windows icon size is set to normal, so any body have an idea what the problem can be?
    Thanks Rob
    I'll get it finished sometime after I start it.....
    Try enabling "Auto Screen Enlarge" in General Config, then restart Mach3.
    Sounds like the screenset is designed taller than 768.
    Apr 2005
    253
    Thanks Gerry that was it, I had tried selecting that option but hadn't closed and restarted mach3 so it had looked like no change so unticked it again, good lesson to learn, restart mach3 after any changes!
    Cheers Rob
  1. Best 5 Axis screen
    By firstyear in forum Screen Layouts, Post Processors & Misc
    Last Post: 09-18-2011, 01:56 AM
  2. 4th axis positioning is not posting correctly.
    By TXFred in forum Mastercam
    Last Post: 06-10-2010, 02:06 PM
  3. Grid not displaying correctly in d-cad
    By windy_miller in forum Dolphin CAD/CAM
    Last Post: 11-28-2008, 02:13 AM
  4. Z Axis is not working correctly.
    By Rich05 in forum Charter Oak Automation Support Forum
    Last Post: 09-22-2008, 03:29 PM
  5. Bridgeport VMC760/20 Z axis not positioning correctly for tool change
    By seano_78 in forum Bridgeport / Hardinge Mills
    Last Post: 08-14-2007, 09:38 PM
