586,024 active members*
4,064 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Contouring Violating Surfaces
Results 1 to 10 of 10
    Aug 2012
    Hello,
    I am new to MasterCAM. Can you set it so will automatically know where each surface is and not violate/ crash into the surfaces, even if I didn't select them, set any bounds or set check faces?
    Thanks in Advance,
    Hades
    201
    You have to tell Mastercam that the surfaces are there.
    Sep 2011
    27
    Select them as check surfaces. Or use a sketch as an avoid area.
    John
    201
    using check surfaces is one way to have mastercam avoid hitting surfaces you don't want to hit.
    Aug 2012
    Quote Originally Posted by JIMMY View Post
    by one way do you mean there are others? I'm looking to remove as much possible error as possible, is there a way to automatically select all surfaces?
    Nov 2006
    19
    you can with a 3d highspeed toolpath then create a containment
    201
    like nw Phil said 3d highspeed toolpaths can do that. you can create a boundry and select the model and mastercam will cut everything in that boundry. if you want it to stay away from some of the surfaces you have to make check surfaces or offset the surfaces. I don't recommend you offsetting surfaces but if you had to you can. hope this helps.
    Apr 2003
    3578
    All surface paths can use a tool boundary well 95% of them can. this will contain the tool in an area that you create the tool boundary from.
    ANd Like John said you can also still use a check surface and define how close it can come to that surface.
    Cadcam
    Apr 2003
    3578
    Quote Originally Posted by JohnWLMT View Post
    John
    John do you mean a tool boundry when you said use a Sketch as an avoid area?
    Cadcam
    201
    I was also wondering if he meant boundry also.
  1. contouring
    By joemech in forum GibbsCAM
    Last Post: 01-27-2012, 12:32 AM
  2. Help with 3D contouring
    By Kevin77 in forum Dolphin CAD/CAM
    Last Post: 06-02-2010, 11:55 AM
  3. 3D Contouring????????
    By cut2spec in forum Benchtop Machines
    Last Post: 03-18-2007, 07:08 PM
  4. contouring help
    By rbest27 in forum Surfcam
    Last Post: 02-02-2007, 04:14 PM
