585,557 active members*
3,343 visitors online*
    Jun 2008
    30
    Glass engraving
    Which is best lens to use for etching or marking fine piece of glass ?
    I have a piece of glass , diameter 3mm and need to right down very small number on it.
    Feb 2012
    387
    glass
    Hi ,
    Usally we use 60w laser power with 50mm lens engraving and some time we place a piece of paper on it,to prevent the laser rays reflect,what is your opinion?
    Hope this can help you
    Best Regards
    Lucy Lee
    G.WEIKE LASER
    [email protected]
    Quote Originally Posted by yasam2002 View Post
    Aug 2012
    46
    Using a wet paper towel over your glass when engraving could reducing the shattering of it and create higher precision result. (That what I've read anyway)
    I've also seen comment about combining Laser cutter and sand blasting to create deeper higher res result.
    You need a 1.5" lens to engrave this
    3mm is VERY small .. whatever lens you use , you will struggle to get lettering below 1mm that is crisp and readable on a 3mm diameter piece of glass , especially cos glass does not vaporise , it actually shatters due to thermal shock which leads to ill defined laser engraving.
    Rodney , Cape Town , South Africa
    www.tokerbros.co.za
    Nov 2009
    314
    With focus lens lower than 63.5 mm and laser tube lower than 80 W , it will give a good engraving work . Letters height of 1.5 mm are engraved on MDF as the picture .Glass and Acylic also will do . What's your opinion ?
    Attached Thumbnails Attached Thumbnails Engraving  letters height of 1.5mm .jpg
  1. Glass photo engraving
    By Pysiek in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-01-2014, 02:48 PM
  2. Glass Engraving
    By SHADOW042 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-14-2011, 12:38 PM
  3. Engraving Glass w/ CNC
    By mredican in forum Glass, Plastic and Stone
    Last Post: 04-28-2011, 11:02 AM
  4. Engraving (glass and acrylic)
    By fibonacci in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-02-2010, 11:47 PM
  5. Glass engraving
    By julianh in forum Uncategorised MetalWorking Machines
    Last Post: 08-11-2009, 02:10 AM
