585,749 active members*
3,975 visitors online*
Thread: BLDC motor
Results 1 to 9 of 9
    Sep 2004
    5
    BLDC motor
    Can a vsd-e drive a BLDC motor without encoder?
    May 2009
    281
    it has to have some way to sense the commutation requirements of the motor, either hall effect or encoder. if you don't have hall effect, or encoder no, if you do have hall effect and no encoder, I don't know, but I think not.
    Aug 2007
    558
    Quote Originally Posted by fraspelle View Post
    With hall sensors yes, but custom firmware is required. You might like to ask at Granite Devices Support
    Kind regards,
    Jason
    Sep 2004
    5
    Hi
    I have two of these motors. I have to figure out how to attach an encoder because the motor shaft is not in both ends
    I ordered the VSD-E just to run these motors, and i hoped it would be possible to drive them "as is" without modification
    24220
    Looks like you have the three commutation outputs there, either hall effect or optical equivalent.
    But usually an encoder is need in servo positioning applications.
    Al.
    Albert E.
    Aug 2007
    558
    Yes, they look like they ought to work as is but you will need to get the firmware required to run without encoders.
    Torque mode only, as Al says - not for positioning.
    Regards,
    Jason
    May 2009
    281
    are you going to be running a timing belt, or a coupling ? if you are going to drive a timing belt you could probably run a shaft encoder from the opposite side of the pulley. you would have to build some sort of frame to hold the encoder, but it should be doable. I couldn't read the label on your motor, but a web search might give you more information on it.
    Sep 2004
    5
    Thank you all for the replays!
    I have searched for information without success. The motors was mounted in a pump for medical instruments. They are China made by a company name xiangming(http://www.xiangming.com/) But I did not find any info about them. I tried to download some info on some of the other motors they made, but the download does not work from their site
    I have the controllers that drive them so I think I can figure out the wiring, but it had helped a lot to find the info on them.
    They are 24v, 1700 rpm and torque more then enough for my need.
    /pelle
    Mar 2020
    Re: BLDC motor
    A moor without encoder, does it mean motor is not working? Or it have anything else, Or have some kind of other information for us. You can have to show xpertwriters.com but that place where you cannot make your lines perfect then that whole work is going to waste.
  1. 8.4kW Spindle Motor BLDC From RC Airplanes
    By Fish4Fun in forum DIY CNC Router Table Machines
    Last Post: 06-16-2015, 02:33 PM
  2. Regarding Transferfunction of BLDC Motor
    By pathamuthu in forum CNC Machine Related Electronics
    Last Post: 01-27-2009, 09:30 PM
  3. Electrocraft BLDC motor, need some spec's.
    By lucas in forum Servo Motors / Drives
    Last Post: 02-17-2008, 07:53 PM
