Hi Folks, I hope some of you can help me with this problem I'm having.
I'm trying to drill a 6 mm (63 mm deep, using a solid carbide drill) hole into a piece of steel that has been hardened to 60 HRC. My problem is the drills are breaking randomly, and my guess is that when using the G83 cycle the drill moves into the hole in rapid feed, which means if a little chip is stuck, on either the edge of the hole or on the drill itself, it will get dragged into the hole at rapid feed and thus breaking the drill.
I have tried to set the safe distance to 63mm meaning it would always start feeding above the hole, but my cam software tells me it would take several days to complete one hole (which I'm not really interested in :nono. I was adviced to run at 350 RPM and with a feed of 2 mm/min and pecks at ½ mm.
Any suggestions on how to stop breaking drills?
//Lene Madsen
