585,727 active members*
4,189 visitors online*
    Aug 2005
    300
    Extract edges
    A friend wants me to draw up a motor cover that is made from 1x1x.125 angle iron and expanded metal. He wants a 3D drawing on the print as well as the dimension drawing.
    So I started out with the frame as a solid and tried the extract edge feature but I do not know how to get rid of the color of the solid to show the extracted edges. Can anyone tell me how to do this. If it is in the help file, I missed it.
    Also does anyone know where I can find cad drawings of expanded metals that I can import and save the tims of drawing my own?
    Any help will be appreciated.
    Ernie
    Feb 2009
    48
    you need to open a new layer befor extracting the edges make sure the new layer is active befor extracting the edges then just unchech the visibility on the solids layer and youll be left with just the edges
    Jun 2008
    1838
    Quote Originally Posted by ErnieD View Post
    Ernie
    Ernie
    After you do the extract edges just click on "blank" and then select the solid and right click and the solid will be hidden
    Here is one link for extruded Aluminium section, you can download the CAD as a 3D STEP, Solidworks 2008 or Inventor, suggest you use the STEP file option if you want to use any of these downloads.
    MiniTec T-Slotted Aluminum Extrusions. Modular Aluminum Profiles For Custom Construction From Aluminum Extrusions. Custom Clean Rooms, Ergonomic Workstations, Belt Conveyors, and Machine Guards Are But A Few Applications.
    Below is an image of a STEP file I downloaded from the link above and extracted the edges from it then copied it and "blanked" the solid to show the wire frame
Name:	Blank Solid.jpg
    You can see there is now a solid and a wire version of the part
    Hope that helps
    Regards
    Mar 2010
    1852
    It is also easy to blank out a solid by hitting the "S" key. It toggles visibility on and off.
    AS previously mention, when extracting edges create a new layer and choose your color before doing it.
    Mike
    Aug 2005
    300
    Unhappy
    Guys,
    Thanks for the replies and tips. I find the blanking method in the later versions of BC to be very unhandy. I liked the way it was done in v20. I do not like the way it works now as a toggle switch. What I expect to see when I use blank is that the selected entity goes away and when I use unblank it comes back. Simple. But no, BC has to complicate things.
    Also, I don't know if any of you guys have heard of my "zooming" problem? I have a situation where when I select, for instant, break many and move the cursor into the workspace, everything zooms to the extent that I cannot see anything. I can select zoom fit all it comes back but if I move the cursor back into the work area it zooms again.
    All this is very frustrating. As far as I am concerned my v23 and v24 are as buggy as an ant hill. I wish that they were as stable as v20 then I would be all set. I have had several people from BC try and resolve my problem to no avail. This is getting so bad that I am going to have to chuck Bobcad and learn another software. At my age, 79 , I do not need these problems.
    ERnie
  1. How do I extract a broken drill bit from a deep hole?
    By slashmaster in forum Benchtop Machines
    Last Post: 09-22-2011, 10:10 PM
  2. THE BEST WAY TO EXTRACT HELICOIL INSERTS?
    By david rendon in forum MetalWork Discussion
    Last Post: 03-25-2011, 07:31 PM
  3. Edges Not Selectable
    By jdmay in forum SprutCAM
    Last Post: 08-15-2010, 10:33 PM
  4. Edges on STL Model
    By jeffrey001 in forum Mastercam
    Last Post: 08-13-2010, 04:50 PM
  5. extract data from hole chart
    By kendo in forum Autodesk
    Last Post: 12-09-2008, 10:24 PM
