Hey guys, I have a Taig CNC mill and am having a bit of trouble with getting some rough edges on the machines edges of the parts I am making.
I am running at 5ipm, about 2K on the head using a 5/32 2flute carbide end mill (.06 doc). I have retuned the mill to ensure no run out and the ways are really smooth, (no wag or run out as far as I can measure).
I am machining parts from .25 inch aluminum, they are small bearing blocks and I am basically taking strips of 1.5inch by .25 inch thick aluminum, milling the bearing seat and then cutting the part out by machining the outline of the part. I am fixing the stock in with some pretty decent vices by taking the strip, laying it flat in the vice (over a piece of wood) and tightening the vice down real well. I am brushing on some lubricant in the begining with an acid brush (tried cutting oil and kerosene on separate occasions).
My edges look really crumby, can you guys suggest some things to look for so I know how to chase this down?
