i just got a new machine, and i came with the optional software winpcnc USB, that has a USB motion controller.
The idea was to use it on a laptop, and be able to also use Mach3 on the same machine with the same USB motion controller.
After trying it, it only worked with winpcnc and not mach3; the company, that originally told me i could use both programs with it, acknowledged that in fact i can't run Mach3 on the USB mc, only through a parallel port.
Then i will have to get together a new desktop for it, and not have a motion controller when using Mach3.
So now i want to return Winpcnc USB for a refund, and get a cheap XP desktop (like a P4), do a fresh OS install and have it only to run Mach3 through the Lpt.
I only have a doubt about this: will it run as smooth as Winpcnc with the motion controller or can i get some uneven or jittery movement?
Mach3 is so much more full featured than Winpcnc, that i really would like to use it, but then if the movement is not very even, the final result, what really counts, might be worse. And i don't like the idea to ALSO get a smoothstepper; i was told by the machine's manufacturer they were offering smoothsteppers in the past but stopped because of several problems. It might not work well with the motor controller i got with the machine. In fact, for the motor controller, they specify parallel connection or USB connection with winpcnc USB.
What would you do? I don't have a lot of time to decide to return Winpcnc USB or not and it's more than $400.
Thanks for all the suggestions,
D.
