I'm newbee to foam molding. I'm going to make one, for the first time and have 2 questions:
1. I'm going to cnc machine it and this foam-spray is being sold in different types. What parameters should I tell the seller so that he gives me a brand that is closest to what needed for good cnc result? May be, that the foam result must be the hardest one, etc.?
2. What else should I buy so that after cnc machining, I can make a mold surface around the foam, which closes all holes and leaves a smooth surface please?
Thank you,
