585,886 active members*
5,945 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > HAAS OTS Renishaw Probing Issue....
    Mar 2011
    10
    Exclamation HAAS OTS Renishaw Probing Issue....
    Need help figuring out why my offsets are always +.15 after probing. I have recalibrated the tool probe and work probe...by the book! Took exact measurements to find exact gauge line numbers, checked spindle for any kind of unusual movement, still .15 off. Every time the offset of the tool is positive that much. Machine offsets are fine because I have reverted back to using dial presetter for now. Any kind of help would be greatly appreciated! Thanks in advance!
    '08 Haas VF-4
    May 2004
    97
    I assume you are talking length. How did you calibrate the spindle probe length?
    if you adjusted the tool offset length value of the probe by the error would they come back right?
    May 2004
    4519
    I have been seeing more problems with probing that were probably due to corrupted 9xxx programs that were corrected by reloading these programs. Might want to look into that also.
    Mar 2011
    10
    guypb, yes I am talking probe length. But I did find out that the work probe is off in x and y also. Started using a standard edge finder and found that also. Luckily I have been finding center on all my parts so far until now. Just thought it would be a good idea to double check it and glad I did. The way I calibrated the probe length was with a dial indicator and a factory cad drawing of the holder I was using....."gauge line to edge of holder flange" + "edge of flange to ruby tip" Hope that makes sense.
    txcnc....thanks for that input as well, I will try that also!
    Jul 2011
    Use a dial indicator to sweep in the probe tip to within .0002 then go into VQC and use the probe calibration programs.
  1. Renishaw probing.
    By jpj1474 in forum Mach Wizards, Macros, & Addons
    Last Post: 05-02-2012, 11:18 PM
  2. renishaw probing on haas mini mill
    By kwhite2 in forum Haas Mills
    Last Post: 09-30-2010, 10:51 PM
  3. tool probing issue, probe open ?
    By parksteel in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-06-2008, 05:28 PM
  4. Renishaw probing -- NON VQC
    By gromit68 in forum Haas Mills
    Last Post: 01-20-2008, 04:34 AM
  5. Renishaw probing setting workshifts
    By Liontastic in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-07-2007, 08:25 PM
