585,902 active members*
4,480 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Canned Cycle Finish Starts in Wrong Position
Results 1 to 8 of 8
    Sep 2008
    199
    Hey,
    I'm turning down a reduced diameter on a bar. My roughing cycle goes fine. When it's done it oddly retreats to a start point 0.020" closer to my tail stock then I expect it to and then makes a tiny cut in and starts the finishing pass. I want to get rid of this tiny vut in but for the life of me I can't figure out what's causing it which means it's probably cutter comp or sometihng like that. I could just get rid of the finishing pass all together but I feel like that's letting the machine defeat me. I'm using a TL-1, below is the code:
    O00056
    G18 G40 G64 G80 G97 G99
    M09
    T606 (T)
    G97 S500 M03
    G54 G00 X0.535 Z-2.25 M08
    G96 S300
    G71 P101 Q102 U0.003 W0.002 D0.01 F0.006
    N101 G00 X0.532 Z-2.25
    G01 G42 D3 X0.528
    G02 X0.2494 Z-2.3847 R0.187
    G01 X0.2497 Z-3.0625
    X0.2514 Z-3.7403
    G02 X0.53 Z-3.875 R0.187
    G01 X0.53
    N102 G40 X0.55
    G70 P101 Q102 F0.002
    M09
    G00 X4. Z0 M09
    M30
    -JWB
    --We Ain't Building Pianos (TCNJ Baja 2008)
    May 2004
    4519
    I disagree with your lead-in and lead-out moves. What is the nose radius of the tool?
    Try something like this:
    O00056
    M09
    T606 (T)
    G97 S500 M03
    G54 G00 X0.55 Z-2.2 M08 <changed
    G96 S300
    N101 G01 G42 D3 X0.528 Z-2.25 <changed
    X0.2514 Z-3.7403
    G01 X0.53
    N102 G40 X0.55 Z-3.9 <changed
    M09
    G00 X4. Z0 M09
    M30
    Sep 2008
    199
    The Tool Radius is 0.0312
    I'm going to try the program you gave me in a little bit. I'll let you know how it goes this afternoon. Thank you.
    What was the logic behind the changes the lead in and lead out? Most of my work comprises running programs similar to this and I'd like to have a better understanding of what's going on. I thought I understood G02 Commands but when I'm not turning a 90 degree radius I get confused, ie if the radius I want is .250" but the change in diam is less than that. I've had issues where instead of getting, for lack of better terms, a paranthesis I get a smile. Haha that sounds ridiculous. I can upload a sketch later if you need.
    Thanks again.
    -JWB
    May 2004
    4519
    The practice for years as applies to older controls is that the lead-in and lead-out moves must equal or be greater than the radius of the tool (as input in the tool table). I do not know if this was the actual problem, but potentially if could have been. Also having the ending X being larger than the start point X would cause the tool to drop the the start point X while returning to the start point Z at the end of the cycle. For your part, I do not think this would have crashed, but I could give an example where it would crash into the part if you would like.
    Sep 2008
    199
    Hey,
    Still no luck. I put up the graphics images generated on my machine. 0503 is your program, 0504 is the one I posted.
    -JWB
    Aug 2010
    579
    Haas Factory Support
    As stated previously, cutter compensation logic dictates the lead-in/out must be greater than the radius of the tool.
    Change these three:
    N101 G01 G42 D6 X0.528 Z-2.25
    N102 G40 X0.562 Z-3.9
    Ken Foulks
    May 2004
    4519
    I think you are seeing the results of 2 things happening. One is in the System Settings and has to do with the amount the tool backs off the cutting in both X and Z during roughing cycles. The other is the W in the roughing cycle itself, the amount to leave for finishing.
    You might consider switching to G73 cycle for this and leave W at 0.000.
    The alternative is to write your own tool movements for each roughing pass.
    Aug 2010
    579
    Quote Originally Posted by txcncman View Post
    I think you are seeing the results of 2 things happening. One is in the System Settings and has to do with the amount the tool backs off the cutting in both X and Z during roughing cycles..
    Excellent point, setting 73 controls the canned cycle retraction. Reduce this value and you should be able to see the difference.
    Ken Foulks
  1. G72 canned cycle
    By 60rock in forum Mastercam
    Last Post: 10-25-2014, 09:39 PM
  2. G71 CANNED CYCLE
    By Jking7489 in forum G-Code Programing
    Last Post: 05-06-2012, 07:18 PM
  3. Cutting starts in wrong place...
    By Grip_Us in forum Techno CNC
    Last Post: 07-02-2010, 03:18 AM
  4. Canned cycle
    By tsaladyga in forum Post Processors for MC
    Last Post: 08-30-2009, 12:31 AM
  5. is there any wayto have my router come on when cycle starts
    By reeftoker75 in forum DIY CNC Router Table Machines
    Last Post: 03-23-2009, 11:08 PM
