586,011 active members*
4,057 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Jun 2012
    Coolant Pump Issues
    I've been having problems with the PCNC 1100 coolant pump since purchased new several months ago. If I don't run the coolant pump every few days, the shaft sticks. The pump must be removed, the shaft manually rotated (using pliers), and then reinstalled for use. I thought maybe the coolant:water ratio was off, but I followed the recommendations on the bottle.
    Is anyone else having problems like this with the coolant pump?
    Jul 2012
    wonder if switching coolant would be a good idea?
    Jun 2012
    I'll try that next. Thanks
    Jun 2005
    656
    My elderly pump does that and it's pretty annoying. I just pull it partway out of the tank and give it a twist.
    Feb 2006
    55
    I've had the same problem. You can actually access the shaft without removing the pump - you can get a pair of pliers on the shaft just below the motor. It appears that I may have finally solved this problem by coating the bottom of the impeller with anti seize lub. 5 months and counting - worth a try.
    Dec 2009
    458
    The coolant pump on my 770 finally gave up the ghost after several weeks of displaying those very symptoms.
    Since I didn't have the spare change to buy another pump I went down to my local Home Depot and bought a sixteen-dollar Evaporative-Cooler-Pump to get me by.
    I cut the legs and impeller shaft in half and added enough length to the plastic legs to reach down to the bottom of my coolant tank and extended the length of the shaft to do the same.
    To keep the impeller spinning true I milled and installed a micro-ball-bearing holder near the bottom of the impeller shaft.
    I've been using it on-and-off for three weeks now with absolutely no problems.
    I used some aluminum flat bar to lengthen the plastic legs on the pump housing. For the impeller shaft I used a short length of 3/16" metal rod. I happened to have that metal laying around so it didn't cost me anything.
    I think the hole project cost me under twenty-bucks and a couple of hours to fit it all together.
    In the end I got a reliable and inexpensive new coolant pump.
    Incidentally; my coolant Tank is a large Tupperware style plastic container.
    When I first went about looking to buy a coolant setup the cheapest one I could find at the time was about $175.00 plus shipping. With that in mind, I think I did pretty good. That twenty-bucks went a long way.
    MetalShavings
    Feb 2006
    7063
    An inexpensive sump pump, available from any hardware store or home center, also makes a perfectly good coolant pump. I've got two that cost me under $50 each.
    Regards,
    Ray L.
    Aug 2012
    21
    Quote Originally Posted by eficonnection View Post
    My pump stated having the same issues. Machine is about 3 months old now. If I dont run the pump for about 4 days it won't run unless I take it out and give it a spin with some pliers. Gonna give Tormach a call tomorrow and see what they say about it.
    Jan 2012
    789
    Yea, it's a common problem.
    Recently, my pump had a bearing fail for the second time. (When cleaning out the coolant box, don't leave the pump upside down. Coolant runs down the shaft into the bearings.)
    I've never been happy with the lack of power on the coolant pump. Went to Menards, bought a $50 1/4HP sump pump designed for continuous operation. WOW does that thing have power!!!! I love it. No more recutting chips, even on deep pockets. I'm really putting that shower curtain to good use.
    Aug 2011
    A simple capacitor on the pump will fix the issue.... But if bearings are your issue, then better bearings or better coolant is your fix...
    Jun 2012
    111
    Add 1 more to the list of users. With this problem. My machine was purchased in the spring, which seems to be a common variable.
    Feb 2006
    55
    Quote Originally Posted by Jeff E. View Post
    Just to clarify my statement. My problem has never been bearing related - but was always a sludge build up under the impeller - the longer the machine sat idle the more the sludge adhered to the bottom of impeller and would stall the pump from starting up. I would spin it with a pair of pliers and it would work for a day or so - I would disassemble the pump clean out the sludge and away it would go for a longer period but would always reoccur. By coating the bottom of the impeller with standard automotive anti seize lub the problem has not reoccurred.
    Feb 2006
    1072
    Quote Originally Posted by tbaker2500 View Post
    Which one is that, Tom? I don't see anything on the Menards website that quite matches your description. (The nearest Menards is the better part of 400 miles north of here...)
    Thank you,
    Randy
    Jun 2012
    111
    I coated mine with Anti-Sieze yesterday. It had been sitting for a few weeks and was locked up with a crystaline type sludge. We'll see how it does.
    Jan 2012
    789
    Quote Originally Posted by zephyr9900 View Post
    Thank you,
    Randy
    I just glanced at their website, and it's not there. Must've been an in-store special. I can look up the exact model if you want when I get back into work.
    It's a multi-purpose pump, rated for waterfalls etc. No float switch. But honestly I would go with something a little smaller. That puts out a LOT of water. Even with two nozzles the flow had to be cut down.
    I'll look up and see how many GPH it is.
    Feb 2006
    1072
    Thank you, Tom. I appreciate it. My stock pump shaft doesn't freeze, but the pump goes through periods of not pumping when I turn it on. Repeated on-off cycling will usually get it to "prime" but by then my cut has been going flushless for a while.
    (Assuming that your pump is a submersible) I'd rather go with a pump that is proven to work down in the coolant and tramp oil glop and all that accumulates in the sump than to just pick something out of a catalog and hope.
    Randy
    Jan 2012
    789
    It's made by Decko Products. It's called a Barracuda Submersible Utility Pump, model 91250. It's 1/4 HP, Continuous Duty. It'll handle solids up to 1/8".
    At 0' rise, it will do 25GPM. 5', 22GPM.
    I throttle it back to about half power. If you run the standard coolant collection tray and box, it will have trouble keeping up with this throughput. I've modified my setup so the water dumps out of a slot I cut in the side of the tray, down a ramp into a bigger collant tank (storage box). So much easier to clean and maintain.
    Feb 2006
    1072
    Thank you for the information, Tom. It turns out that Menards does show it on their website. I use a homemade sump (there's a picture in this post) that holds about 11 gallons. The strainer usually sits on the return sub-tank, which pokes up through a hole in the removable half of the sump lid.
    Randy
    Jan 2012
    51
    Would you mind posting a picture of your coolant tank setup? I am keen on 'easier'...
    Geo
    Jan 2012
    789
    My setup ain't nearly so nice. Any small chips that make it through the main screen just get re-pumped. I'll post pics/video of flow rate in a few days.
Page 1 of 2 12
  1. Tm Coolant Pump
    By behindpropeller in forum Haas Mills
    Last Post: 03-15-2010, 04:45 PM
  2. Coolant Pump
    By bobs_charger in forum Tormach Personal CNC Mill
    Last Post: 04-16-2009, 11:19 PM
  3. coolant pump
    By JACKSMACHINE in forum Fadal
    Last Post: 05-22-2008, 09:13 PM
  4. TM2 Coolant pump
    By Peter Gibbs in forum Haas Mills
    Last Post: 05-03-2008, 06:11 PM
  5. Coolant Pump
    By Smackre in forum Mechanical Calculations/Engineering Design
    Last Post: 06-29-2007, 07:16 PM
