586,009 active members*
4,913 visitors online*
Results 1 to 6 of 6
    Jun 2010
    Fanuc problem
    HI
    PLEASE MY CNC FANUC OM MACHINE AXIS MOVING IN JOG ALSO GOING TO REFRENCE POINTS ,ALSO SPINDEL WORK CORRECTLY ,BUT WHEN I WROT FOR EXAMPLE :
    G00 X100;
    TO MOVE THE AXIS
    IN MDI MODE AFTER PRESSING CYCLE START KEY THAT RED LED LIGHTUP BUT
    NOTHING HAPPEND TO MOVE THE X OR Y OR Z AXIS DO YOU KNOW WHAY ?
    THANKS
    Jan 2011
    350
    Seems dumb but feedrate % is 0 on your rotary switch?
    May 2004
    4519
    Most machines zero is at the maximum positive Z movement. After zero reference return, if you try to program additional positive movement, it will not go. Try G00 X-100.
    Jun 2010
    Quote Originally Posted by botha.y View Post
    hi:
    thanks for your reply me : But Federate on the Rotary Switch is %100 But no move any axis ,my parameters was lost because Backup battery was empty
    after Reentered I found this problem I think my Parametrs or Diagnostic Parameters maybe is not correct
    Jun 2010
    Quote Originally Posted by txcncman View Post
    Thanks for your guid, But I tried to G00 X-100 again nothing to move my parameters was lost I entered again I thing some parameters are wrong!!
    what you thinking?
    thanks
    Jan 2011
    350
    Quote Originally Posted by majid View Post
    hi:
    If you uploaded your backup params and diagnostics properly I don't see why it would be this. Can you get the axis to move in G01?
  1. Fanuc OM-C pmc problem
    By rai in forum Fanuc
    Last Post: 01-15-2022, 04:56 AM
  2. Problem with fanuc 01
    By dopamine in forum Fanuc
    Last Post: 04-11-2010, 04:31 AM
  3. PROBLEM ON FANUC 0GD
    By vinoth in forum Fanuc
    Last Post: 03-17-2009, 06:15 PM
  4. Fanuc 18M oil problem
    By mustafaguler in forum Uncategorised MetalWorking Machines
    Last Post: 09-18-2008, 08:35 AM
  5. Fanuc new 0I problem
    By sylvain in forum European Club House
    Last Post: 12-30-2007, 06:17 PM
