585,978 active members*
4,132 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Smoothstepper (ethernet)
    Sep 2010
    72
    Anyone using the ethernet version of Smoothstepper and care to comment on how it was to configure, how it is worked for you, etc ? Or PM me
    thanks
    Jun 2011
    I have one sitting on my desk, that I need to find time to install and setup, might be a few weeks before I get to it.
    You minimally need an additional 5V supply for the smoothstepper, from what I can see configuration should not be overly arduous but it does require a very recent version of Mach which could be a limitation for some.
    I'm looking at using it to provide an input for an MPG and a probe.
    Sent from my iPad using Tapatalk HD
    Jul 2008
    340
    I bought an ESS when I discovered that the parallel driver would not work with Windows 7 64-bit and that a PCI-E 1X version of the parallel port card ran me a fourth of the cost of the ESS.
    I'm running the ESS attached to a PMDX-126. It installed without a hitch. I am powering the ESS from the P1 and P2 ports on the PMDX-126. It works like a drop-in replacement for the parallel ports.
    The only hitch I have run into, is enabling homing on a slaved axis (X & A on my CRP-4848). Greg from Warp9 has confirmed that the problem exists and it's at the top of his list to fix. Hopefully we will see a fix soon. Until then, I have been experimenting with alternate homing solutions using PMDX's proximity switches.
    I like the ESS and would recommend it. Take that recommendation with a grain of salt since I'm a complete newbie and I'm learning all of this on the fly <grin>
    Sep 2010
    72
    thanks guys.
    rpovey - how come you are looking to use the ess for a mpg and probe input instead of just using your pc with mach?
    Jun 2011
    I am using my PC with Mach the smooth stepper is just a motion controller, but it happens to have additional inputs that I will use for the mpg.
    I could just put in an additional parallel port card, but I'd rather use Ethernet than a long parallel cable, and it'll let me run the drivers with a higher micro stepping value.
  1. Ethernet Smoothstepper Windows Firewall Settings
    By surfmachine in forum SmoothStepper Motion Control
    Last Post: 07-21-2012, 06:37 AM
  2. Smoothstepper for CNC?
    By Litemover in forum DIY CNC Router Table Machines
    Last Post: 07-15-2012, 06:34 PM
  3. Mach3 Plugin for Ethernet Smoothstepper
    By dwilson26 in forum SmoothStepper Motion Control
    Last Post: 01-31-2012, 07:35 PM
  4. What next, should i try the Smoothstepper?
    By sylvester1073 in forum Controller & Computer Solutions
    Last Post: 08-01-2010, 10:32 AM
  5. Anyone tried a Smoothstepper?
    By Ranscon in forum CNC Machine Related Electronics
    Last Post: 03-07-2009, 07:37 PM
